Results 1 to 3 of 3
Thread: What determines Fuel Pressure Desired?
    Jan 2016
    Default What determines Fuel Pressure Desired?
    Hello,
    I am trying to trouble shoot why my truck wants to idle at 8k. I have basically a stock tune converted to a single event and deletes. I noticed today that the ECM is commanding the pumps to raise the rail pressure to 8k (log attached).
    Any help you can give me is greatly appreciated!
    Oct 2017
    Could the ECM be thinking the Pedal Position is at a different point or at 0% throttle you're asking for more fuel which pushes you to 8k?
    2012 2500 Mega Cab
    Mineral Grey, Two-Tone Laramie
    Gauges, EFI Live, Leveling Kit (Nitto Trail Grappler 35x12.5x17 Method NV's)
    Nov 2010
    Ecm requires more mm3 to maintain idle quality, thus pushing your rail up
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  1. Desired Fuel
    By cjowett in forum Cummins 6.7L
    Last Post: January 7th, 2016, 02:02 PM
  2. How to check and log cp3 desired vs actual pressure
    By cpurtellII in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 21st, 2015, 01:35 PM
  3. T43 TCC Desired Slip and Adaptive Pressure
    By Longslyde in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 11th, 2012, 07:42 AM
  4. can I log fuel pressure with my glowShift fuel pressure gauge?
    By ryans1000 in forum External A/D inputs
    Last Post: August 16th, 2011, 01:35 AM
  5. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
