Results 1 to 10 of 12
Thread: Oct 2017, Release Candidate 4 (AKA Public Release)
    Default Oct 2017, Release Candidate 4 (AKA Public Release)
    Download EFILive V7.5
    Download EFILive V8
    Release Candidate Version
    This version may now be used by all EFILive tuners and their customers in production environments.
    Barring any serious problems being discovered, this will become the official public download.
    If you do discover a problem with this software, please report it to EFILive as soon as possible by posting in this thread or by emailing support@efilive.com or by logging a support request in the helpdesk.
    Release Notes:
    PLEASE read the "Important Changes" section at the top of the "What's New" document.
    The way EFILive reports/uses software version numbers has changed (new in RC2).
    The way EFILive reports and manages out of range calibrations has changed (new in RC1).
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.13 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.8 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.126 (Oct 18, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    In V8, when I try to open a listed .ctz (either by double-click or by rightclick->Open Item), I get this error popup...
    ( I verified that the file's path/name actually exists )
    What happens if you double click on the actual file from Windows Explorer? Does it open the file?
    Does it create a new entry in the EFILive V8 Quick Start list?
    If a new entry is created, can you see any difference between the old (not-working entry) and the new one? Look in the file \Documents\EFILive\v8\Config\EFILiveScanAndTune.in i in the [MRU Tune] section to compare the quick start entries.
    The file opens in V7 tunetool.
    No, it did not.
    Oct 2011
    When the option to show out of range calibrations is enabled and a cal with a bitmask is loaded, it will show the limit for the entire field rather than just the value that is displayed/saved.
    See below: 16b field 8b mask. Multiplier is 32.
    03 6spd
    Is this 68RFE parameters?
    Oct 2011
    Yes
    03 6spd
    Oct 2011
    Doing some testing, if you max it out it does not modify the entire field. It works as designed, just displayed odd.
    03 6spd
    68RFE tables, what can I say, who came up with that concept!
    I think the issue is going to be the MAX limit is taken as the whole 16 bits, unfortunately the tune tool was never designed to handle axis and value interwoven so we too have to do workarounds for that.
    No, it did not.
    What if you right click the file in Windows Explorer and select "Open with EFILive V8"
  1. Sep 2017, Release Candidate 3
    Last Post: October 8th, 2017, 12:56 PM
  2. Sep 2017, Release Candidate 2
    Last Post: September 29th, 2017, 08:11 AM
  3. Sep 2017, Release Candidate 1
    Last Post: September 16th, 2017, 04:28 PM
  4. Known issues with Oct 28, 2014 release of the EFILive software and firmware.
    Last Post: January 27th, 2015, 07:42 PM
  5. CSP5 Oct 16 Release
    By cindy@efilive in forum Cummins 5.9L
    Last Post: October 17th, 2013, 05:04 AM
