Results 1 to 3 of 3
Thread: 6l80e code p01825
    Aug 2006
    Default 6l80e code p01825
    Done a l98 /6l80e conversion but keep getting code p1825 in the tcm and is stuck in limp mode i ve swaped the range switch over -no good tryed a different tcm - same code, disabled code in tune and then we have no drive at all i noticed the tcm has a p/n out put on pin 3 i wonder if this needs to go to the ecm and then the ecm sends a signal back to the tcm via can bus?
    Aug 2013
    Might be a mis-alignment between the transmission selector lever and the transmission range switch.
    Aug 2006
    It feels like it dropps on to the gear nice against the detent i might drop linkage off to confirm they have modded the column selector to mate up to the 6l80e
  1. swapping Camaro 6l80e to Vette 6l80e
    By secrt007agt in forum General
    Last Post: January 31st, 2016, 04:43 AM
  2. Odd 6L80E Behavoir
    By Webbs in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 30th, 2013, 02:38 PM
  3. NEED HELP , Trying to calibrate 6l80e.
    By SkywayPerformance in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 12th, 2012, 08:37 AM
  4. Is it possible to put the LS7 and 6L80E together
    By Brads_rs in forum Gen IV V8 Specific
    Last Post: May 17th, 2011, 02:49 AM
  5. Code P062F and Code P0633 Help
    By Airtime in forum General (Diesel)
    Last Post: September 28th, 2009, 01:57 AM
