Results 1 to 4 of 4
Thread: Current Public Release (Oct 2017)
    Default Current Public Release (Oct 2017)
    Release Notes:
    Version Numbers:
    After installing the Oct 2017 Public Release Release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.13 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.8 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.126 (Oct 18, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Issue #3:
    When black-box, cal-flashing an E98 *.coz (calibration only) file, the cal-flash will fail with error $0185.
    Workaround:
    Use pass-thru flashing for E98 *.coz files.
    Will be fixed in the next update.
    Issue #4:
    When data logging using V7 pass-thru logging, the SAE.MAP PID will be scaled incorrectly for late model, forced induction platforms.
    Workaround:
    Use Black Box Logging or V8 pass-thru scanning.
    Issue #5:
    When resizing the main V8 Scan and Tune window to its minimum height, the [F8: Tools] icon is partially obscured.
    Workaround:
    Expand the window vertically.
    Hey Paul, when you open V8 with large EFILive icons and then shrink the vertical size, it will let you cut off the bottom of the F8: Tools button. I have a 1080p screen running at 100% display scaling, also tried at 125%. I also clicked the "Small buttons" option in the "View" menu and it applies correctly to the non-main windows (i.e. Tune files, properties, etc) but not to the main V8 S&T window. I can't remember if this is expected functionality or not, I'll admit it's been a while since I've played with the button sizes.
    The main window [F8: Tools] icon should not get cut off - I'll fix that.
    The "small buttons" option is only designed to control the tab sizes in the sub-windows, not the buttons on the main Scan and Tune window.
    Great, thanks for the clarification on that Paul!
  1. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 08:17 AM
  2. Known Issues With Current Public Release
    Last Post: March 22nd, 2017, 10:42 AM
  3. Known Issues With Current Public Release
    Last Post: February 17th, 2017, 06:06 AM
  4. Known Issues With Current Public Release
    Last Post: January 31st, 2017, 11:02 AM
  5. CSP5 Oct 16 Release
    By cindy@efilive in forum Cummins 5.9L
    Last Post: October 17th, 2013, 04:04 AM
