Results 1 to 5 of 5
Thread: $0533
    Oct 2017
    Default $0533
    I'm seeing on here that this is a pretty common thing, but didn't see any remedy. Went to flash a 2002 lb7, controller was licensed successfully but when I go to flash it I get this code. Any help would be appreciated.
    Start with the basics, are you running the latest version of EFILive V7.5 and V8?
    The public release is the latest available and has versions:
    V8 Software: V8.2.8
    FlashScan/AutoCal Firmware: V2.07.126 (Oct 18, 2017)
    FlashScan/AutoCal Boot Block: V2.07.007 (Feb 07, 2014)
    V7.5 Software: V7.5.13
    Does this vehicle has any aftermarket modules on the VPW bus? If so, disable them all.
    Do you have a bench harness and have you tried flashing on the bench?
    Create a help desk ticket https://support.efilive.com/ and submit the following files:
    A (*.lbu) license backup file from your FlashScan device.
    A file read from the ECM after the $0533 error occurred.
    The (*.htx) trace file that is saved when the $0533 error occurs.
    Jun 2017
    MJ,
    Did this end up working for you? I have still not had my issue resolved from a year ago and I am trying to get it closed up as well....
    https://forum.efilive.com/showthread...889#post238889
    Thank you,
    AC
    Nov 2005
    Quote Originally Posted by ACNorris View Post
    MJ,
    Thank you,
    AC
    For clarity; your post states you replaced your ECM in 2016. You asked for help regarding a replacement license in 2017, and followed up a lack of response in 2018. I'm sorry I didn't see your post until you requested further support one hour ago.
    Cheers
    Cindy
  1. $0533
    By 4794cook in forum AutoCal
    Last Post: December 15th, 2016, 04:03 PM
  2. #0533 LB7 duramax
    By Keiko in forum AutoCal
    Last Post: June 10th, 2015, 09:18 AM
  3. 0533 and 033 erors
    By Phone Man in forum AutoCal
    Last Post: June 13th, 2012, 07:32 AM
  4. Need help : Error $0533
    By wilsonck in forum Diesel
    Last Post: October 28th, 2011, 08:58 AM
  5. error $0533 ?
    By sscbarber in forum AutoCal
    Last Post: February 19th, 2011, 07:22 PM
