Results 1 to 3 of 3
Thread: bouncing idle
    May 2006
    Default bouncing idle
    Hey guys. Getting the car dialed in. After the car is warm sometimes the idle will bounce between 800-1100. When i drive then put the car in nutrial, it idels great at 900. when i come to a stop sometimes it will fluxuate. But sometimes i can pull up to a light, and bam it idle's great at 900. What should i check out.?
    thx
    Oct 2005
    Desired Air flow.
    You can log ect vs rafig from cold startup in a map and add to your desired air table. Do a search for "idle transition" you will see all the info there.
    You might also need to tweak spark/idle under and overshoot timing adjustment downwards.
    2014 VF SV LS3 Maloo.
    Jan 2005
    The BIDI controls are good for finding the spark and AFR your engine likes for idle. Key to idle is getting the B4307 table dialed in.
  1. RPMs bouncing at 2-3 shift!
    By shadyst in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 8th, 2009, 07:50 PM
  2. timing bouncing in maf only tune
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: January 13th, 2009, 06:40 PM
  3. Bouncing WB readin...
    By Naf in forum Gen III V8 Specific
    Last Post: December 3rd, 2008, 12:33 AM
  4. Bouncing off rev limiter
    By TransTech in forum General (Petrol, Gas, Ethanol)
    Last Post: November 11th, 2007, 06:09 PM
  5. Spark Bouncing Around At Idle
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2006, 02:51 PM
