Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Beta Test Release #1 (Feb 2018)
    Default Beta Test Release #1 (Feb 2018)
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing the Dec 2017 Public Release Release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.17 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.13 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.130 (Jan 31, 2018) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Nov 2005
    For those customers who have asked about EFILive_XCal, additional information can be found here http://www.efilive.com/latest/cummin...le-conversion/
    Once the Feburary beta software is installed, EFILive_XCal can be found in the C:\Program Files (x86)\EFILive\V8 directory.
    Cindy
    Unlock and erase selected controllers E38, E40, E67, LS1B, E54 (LB7) and E60 (LLY), by trying all keys in a user defined range. Stopping and re-starting is now also supported.
    Nice, will give this a shot tonight. I normally use a different app to find the unlock codes.
    Dec 2005
    Will this new method repair controller with the $0333 re-arming issues ?
    Thank You !!!
    www.mscservices.net
    I tried to find where i could do this, played around with both v8 and 7.5 and it would always say ecu is locked. Or is this feature not intended to do what i was expecting.. i.e start at 0001 and work its way to FFFE until it finds the code.
    I ran into trouble the other day with a LB7 that was previously flashed with a DSP2 OS that would give me a locked controller warning and a failed flash when trying to do a full with a DSP5 OS. I had to full flash the stock file and then full the DSP5 OS to make it take, is this going to help with that or is this going to help with a corrupted ECM serial/vin?
    04 LB7
    2010 LMM
    2015 LML
    Not everyone has access to that program (I'm thinking of the one that was on Ebay for a while there). Anyway, point is lots of shops asked for this because they were fed up with organising new ECM's or sending them away to be unlocked.
    The difference is we've taken the trouble to help tuners by not just unlocking the ECM and then allowing the unlocker to read back the tune, it is an unlock and flash process in one. That would be the number one complaint with that other tool, it allows thieves to steal tunes. If that doesn't suit people then they need to use the tool you do.
    It would eventually unlock it but the LB7 ECM has issues with locking itself, we can't fix that unfortunately. And I'm sure you've been burnt with TIS locking them up too? Not the best design from GM (Isuzu).
    The option is only available in the cal-flash section.
    The controller is erased and unlocked once the key is found. The key is not revealed.
    The restart option is required if you want to stop it and restart it again without re-trying all the keys that have already been tried. That is because the keys are tried in a random order in the range specified.
    For example if the range was from 1 to 20 the first 5 keys tried might be 3, 18, 12, 4 and 8. If you stopped it after 5 unlock attempts and naively restarted it using the range 6-20 (thinking that it had already tried keys 1-5), then it would never have try keys 1, 2 or 5. And it would have tried 18, 12 and 8 twice - once in the first attempt and once in the retried attempt.
    If you click the [Stop] button to interrupt the range unlock, it saves the "to" and "from" keys, the attempt counter and the key that it was up to in the EFILiveScanAndTune.ini file. That way it can successfully restart (when you check the [Restart] box) from where it was up to - but obviously only for the same controller that was interrupted.
    Dec 2005
    I assume it requires no License to perform the process ?
    I have a WORKSHOP CABLE, but for those that do not, is there licensing required ?
    And will a STOCK TUNE be needed to enable the CAL FLASH ? Or in the case of a locked controller with DSP5 how is that handled for LB7's.
    Thanks Again !!
    www.mscservices.net
    Thanks Again !!
    No, the target ECM does not need to be licensed. However to flash back in a valid calibration the ECM will need to be licensed.
    Once the key is found the ECM is cal-erased and left in a dead-poll and unlocked state.
    The ECM must then be cal-flashed with whatever file is compatible with the controller's OS or full-flashed with whatever file is compatible with the controller hardware/boot block.
    The tune that is loaded while performing the unlock does not need to be compatible with the target controller as it is not flashed into the controller. But it is a good idea to have a valid tune file ready to flash back in once it has been unlocked/erased - otherwise the ECM will be non-function without a calibration in it.
  1. May 2016: EFILive Beta 3 Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: June 6th, 2016, 07:30 PM
  2. April 2016: EFILive Beta 2 Test Release
    Last Post: April 30th, 2016, 08:49 AM
  3. Known issues with the April 2016 Beta Test Release
    Last Post: April 18th, 2016, 05:07 PM
  4. Known issues with the April 2016 Beta Test Release
    Last Post: April 10th, 2016, 08:23 AM
  5. April 2016: EFILive Beta Test Release
    Last Post: April 9th, 2016, 03:46 PM
