Results 1 to 3 of 3
Thread: shift points
    Nov 2017
    Default shift points
    i just installed efi live autocal on my 2015 duramax and it all went well.
    i did the tow tune. the only concern of mine is the shifting on my transmission?
    it goes through 5 of the 6 gears at 3000 rpm in a very short time.
    i assume this it not how it is suppose to shift. anyone have this issue?
    Apr 2006
    The ecm doesn't control shift points. The TCM tune would have to be changed using the autocal for the stock shift points to be adjusted. I'm assuming that your autocal was a ecm flash and not a tcm flash. If you did order a seperate TCM tune, then i would contact your tuner with your concerns.
    Nov 2017
    thanks idaho rob
    youre right it is an ecm tune. do you think a tcm tune is what i need?
    ive read that if i have an efi live autocal i wouldnt need a tcm tune?
  1. shift points
    By shawn prellwitz in forum AutoCal
    Last Post: October 1st, 2018, 10:18 PM
  2. WOT shift points
    By andysc3 in forum FlashScan V1
    Last Post: March 12th, 2012, 01:22 PM
  3. shift points
    By rock04max in forum General
    Last Post: December 1st, 2008, 01:09 PM
  4. Help with 80E shift points
    Last Post: May 20th, 2008, 03:08 PM
  5. TCM shift points
    By lakingslayer in forum General (Diesel)
    Last Post: March 28th, 2007, 11:09 AM
