Results 1 to 5 of 5
Thread: Can I copy .ctz files using file system
    Nov 2017
    Default Can I copy .ctz files using file system
    I have a .ctz file emailed to me but I'm running Linux (currently Mint 17.3). I'm a bit of a newbie to Linux, but I'm not afraid of the command line. I did install EFILive 8 using WINE and then found out about the USB issue. I've done a bit of searching and read some of the threads here but I don't see any solutions. dmesg does show the EFI AutoCal v2 so it is being recognized. It would be great if there was a solution other than a VM (not sure I know where a Windows CD is). Is there a way I can copy the ctz file to the AutoCal using the file system instead of EFI Live?
    I saw some interesting posts about an API to use the Autocal without EFI Live but don't know if that is available. I'm a bit of a programmer, but mostly Java <ducks>.
    If you can mount the SD card into the Linux filesystem, then yes you can copy the .ctz to/from it.
    do ls -l on /dev/sd* to see which device is the SD card.
    No, as far as I'm aware you need to use EFILive Explorer to transfer .ctz files to the AutoCal for flashing. The same applies for retrieving any datalogs from the AutoCal to send back to the tuner for analysis.
    Those APIs are for use via Windows command prompt and for configuring multiple AutoCals at once (helpful for high volume shops).
    Nov 2017
    Default Thank you
    Thanks. I figured that was the answer since I didn't see that as an option, but thought I would ask.
    Looks like I'll be looking for my old Windows CD ...
    Mar 2015
    I
  1. Saving COZ and CTZ files
    By pavetim in forum Duramax 2011+ LML / LGH
    Last Post: June 26th, 2017, 05:30 AM
  2. Unable to Open any E78 ctz file
    By joeygc5 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 20th, 2015, 12:15 PM
  3. Any E92 .tun or .ctz files etc about to have a look at?
    By ringram in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 17th, 2013, 11:31 PM
  4. Files in CTZ or CTD
    By Mike@Vengeance in forum AutoCal
    Last Post: May 7th, 2012, 11:11 PM
