Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: LSX454 w GMPP E67 ECM - Idle Surge
  1. #11
    Feb 2015
    Quote Originally Posted by LastCall View Post
    The throttle closed values makes sense. Limiting the blade by using max area might also help with the over/upper corrections as the blade will not go past that hard limit.
    I️ agree, the airflow is overpowering the fluctuations. The thing is that spark and airflow are both working together to increase RPM, and then cutting it back as well. I
    Try that tune out and see after you reclock that maf. A factory ls3 uses alot more spark correction for large errors. I think around 26 degrees. I would try it than start sneaking in more timing if it helps.
  2. #12
    Member SPi's Avatar
    Jan 2010
    Any word if this has helped your issues. I am currently tuning a GMPP ECM and harness with an LS3 crate motor and I'm having exactly the same issues. Only mods are longtubes and a cam 233/250 .619"/.595" 113+5. I have worked with this cam and many GMPP harnesses before without issue, not sure why I'm having problems with this one.
  1. gmpp e67 idle issue
    By b18cls1 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 7th, 2015, 07:15 AM
  2. Gmpp e67
    By J.Abbott in forum Gen IV V8 Specific
    Last Post: November 18th, 2014, 03:43 AM
  3. KOEO check engine lamp flashing- E67 GMPP ECM
    By 95wagon in forum E37, E38 & E67 PFI ECM's
    Last Post: February 13th, 2012, 02:02 AM
  4. GMPP E67 Issues
    By 540sscamaro in forum E37, E38 & E67 PFI ECM's
    Last Post: October 11th, 2010, 11:12 AM
  5. E67 GMPP dies on decel
    By pandreas in forum E37, E38 & E67 PFI ECM's
    Last Post: February 24th, 2010, 11:30 PM
