Results 1 to 4 of 4
Thread: E92 Procharged Gremlin - Reduced Power Approaching Shift - Shift Stumble
    Oct 2017
    Default E92 Procharged Gremlin - Reduced Power Approaching Shift - Shift Stumble
    I have been working on a E92 Procharged Chevy truck with 6.2. Everything is stock except for 8psi Procharger with air-to-air intercooler. Truck started out with Diablo tune which ran decent on the dyno, driveability was not great. Converted it to EFI Live and have a tune in both the ECM and TCM. Truck runs really nice down low and up to about 3/4 throttle. WOT is where the problems begin. Truck pulls like a freight train to about 5,000 RPM, then it almost feels like its missing as it climbs to the shift and stumbles hard at the shift point, it basically bucks. Then when it is into the next gear the power is back and clean as it climbs again, then the same routine. At first review I noticed the pedal was at 100% but the throttle blade was not. I was able to clean that up in the tune and now it looks like, for the most part, I am getting 100% across the pull. The logs now look pretty clean, however I am seeing the MAP at peak and the MAF at about the same spot. Am I pegging these sensors? Any idea how to clean up the climb past 5000 RPM and the harsh shift stumble? Log_0000 11-11-17 cel.efiLog_0000 11-11-17.efi
    Oct 2015
    Did you ever solve the problem?
    Oct 2017
    Quote Originally Posted by GR8GAME View Post
    Yes I did, it took a very long time to diag. but wound up being a bad MAF. Bought a new one and recalibrated. All seems good now.
    Oct 2015
    Awesome
    Thank you for posting your solution. I appreciate it.
  1. No Shift time adjustment in new 6L80E OS? Adjusting shift times in Torque Model
    By Protec in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 13th, 2013, 10:34 AM
  2. rpm cut off comes up before the 2>3 shift , wont shift
    By Eric in forum Gen III V8 Specific
    Last Post: June 6th, 2011, 09:58 AM
  3. Light for power shift on/off
    By 4wheelin in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 23rd, 2011, 01:57 PM
  4. why 1>2 shift happens at higher rpm than 2>3 shift?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 13th, 2008, 11:54 AM
  5. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
