Results 1 to 2 of 2
Thread: Timing tables incorrect?
    Mar 2014
    Default Timing tables incorrect?
    Quick question to see if anyone has ran into this. Im new to tuning and was using Josh H's timing calc 3.1 but when it generates the timing table it is incomplete? Click image for larger version.
    Member koolky's Avatar
    Aug 2013
    No need to recalculate for 50% below 1400 rpm or at low mm3. Keep in mind that at 50/50 in the calc that you some of the new values will be lower than the stock values which you might want to retain. In the cruising range you may be able to push the timing up above 50/50. There is a lot more that should be considered than just calculating the timing to 50% and pasting that portion to your tune. Its been a while since I've searched but there is a lot of good info and theories on this forum and others
  1. Timing correction tables
    By rcr1978 in forum Duramax 2011+ LML / LGH
    Last Post: April 10th, 2017, 08:01 AM
  2. DOWNshift timing tables. ???
    By killerbee in forum Allison 5 & 6 Speed
    Last Post: November 3rd, 2011, 06:20 PM
  3. says WARNING INCORRECT ETC TABLES on stock tune???
    By conor in forum Gen III V8 Specific
    Last Post: October 12th, 2010, 01:27 AM
  4. Incorrect Axis In OL Fuel Tables
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: May 17th, 2008, 10:23 AM
