Results 1 to 2 of 2
Thread: Tuning for Non-VGT Turbo
    Feb 2016
    Default Tuning for Non-VGT Turbo
    Considering upgrading to a non-VGT turbo in my 2012 Dodge Ram 2500. My question is, what maps must be edited or turned off for it to run smoothly and not throw drive pressure through the roof. I will be doing the tuning but it will be a learning process for me as far as tuning for a different turbo. Specifics are not important just general maps and whether they need to be edited or used at all. I do know there will be a host of DTC's to turn off as well. Thanks
    Dec 2005
    No DTC list appears in the Editor, so unless you have created a CAX file and can edit them within the V7.5 Editor you may need to purchase a tune from a pro who can disable the codes for your swap.
    Good Luck
  1. VGT Tables for E98
    By SV8346 in forum E98 2014+ Diesel ECM
    Last Post: September 6th, 2017, 09:39 PM
  2. Deleting Factory VGT Turbo
    By EverydayDiesel in forum Cummins 6.7L
    Last Post: September 14th, 2016, 10:44 AM
  3. 07.5 6.7 vgt turbo?
    By Scarface in forum Cummins 6.7L
    Last Post: May 8th, 2015, 03:20 AM
  4. Vgt calibration
    By 30 RUM in forum Cummins 6.7L
    Last Post: March 12th, 2013, 04:32 PM
  5. NON-VGT turbos
    By cumminsDK in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 12th, 2012, 04:29 PM
