Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: tunes wont even work?
  1. #11
    Nov 2005
    [QUOTE=08chummins;242293]
    Have you spoken with the company that sold you the Autocal?
    yes I emailed him, he wants me to data log it and show him.. but he said from level 1 to 5 you should easily tell the difference..so right off the bat it's like the tunes never loaded in
    To check the tunes flashed into the vehicle, can you confirm
    1. You did follow the AutoCal license/flash process as detailed here https://support.efilive.com/kb_artic...5899-QLZB-0976
    2. You did license the ecm during the flash process. You can check license status here https://support.efilive.com/kb_artic...9817-YALX-6546
    3. Your tuner has validated he did send you a switchable tune, not a single tune.
    4. You have tested your switch to ensure it is functional. On this point, your tuner will have needed to setup the tune to work with the switch. Other switching options exist including switching via AutoCal. You may try switching via AutoCal if your tuner has setup switchable tuning on the AutoCal menu.
    Cheers
    Cindy
    Sent from my iPad using Tapatalk
  2. #12
    Nov 2017
    [QUOTE=cindy@efilive;242294]
    Quote Originally Posted by 08chummins View Post
    Cheers
    Cindy
    Yes I have done everything said here, I don't get any error codes or anything, I tried changing tunes threw the autocal and no luck..can it be locked to stock or something? (idk much about this lol) Should I go get it flashed to stock by the dodge dealership and try again? or see if they have any answers?
  3. #13
    Dec 2017
    When you try to changes tunes with the autocal what do you see 1-5 .... do they have different names like stock, tow, Economy, street race ect? When you click on it does it say tune whatever now active?
  1. a/c wont work at idle
    By Ctmcamaro396 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 11th, 2013, 06:25 AM
  2. RoadRunner wont work with new laptop
    By minytrker in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 4th, 2012, 02:31 PM
  3. v2 saying at 110% wont work help please
    By restless@westnet.com.au in forum FlashScan V2
    Last Post: March 5th, 2012, 12:41 PM
  4. ac wont work at idle
    By hot-dog in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2009, 04:07 AM
  5. FTClean Wont work
    By Kiwi Ed in forum Tips and tricks
    Last Post: July 28th, 2007, 10:02 PM
