Results 1 to 10 of 10
Thread: P08 Pinout
    Lifetime Member Road's Avatar
    Feb 2015
    Default P08 Pinout
    Anyone have a pinout to make a bench harness for a 99-02 Cavalier with P08?
    Pretty sure it is the same as the LS1B.
    Feb 2015
    No it is different. Even has way less terminal pins. I have tried LS1B, V6 Buick, Northstar pinouts as they are all different too.
    Yes it has less pins but the important ones are in the same spot.
    The LS1B bench harness I have runs all those PCM's you've listed there, V6-P04, Northstar-P06, they are all the same pinout for bench connections (and of course E54 - LB7).
    I just put a P08 on my LS1B bench harness and it works fine.
    Blue 60 = Ground
    Blue 20 = 12V Unswitched (Batt)
    Blue 19 = 12V Switched
    Blue 58 = VPW Serial Data
    Feb 2015
    Blue 60 = Ground
    Interesting... I will try again and count the pins on the LS1B Connector instead of the ecm.
    Oddly if I connect a V6 Buick to my LS1B harness it will blow fuses immediately. (Using a older Kent Moore bench harness)
    Connecting to this Cavalier one and it back feeds power to the key on circuit.
    EFI Connection sells a seperate harness for all these for this reason
    Feb 2015
    My harness had to many wires. I simplified it down and works. You was right as normal... Thanks for the help.
    Quote Originally Posted by Road View Post
    Yeah that's the trick, those four wires I mentioned are common for all those PCM's that look like that.
    Feb 2015
    After all that she is a end of the line ecm with unsupported calibration. Ha. Thanks again though
    Probably a project that should never have happened to be honest, horrible PCM that one.
    Feb 2015
    I never had the calls for them till recently. Local dirt tracks now have a class for these front wheel drive cars and becoming very popular.
  1. Unrecognized PCM? 1997 Buick Skylark P08?
    By Wolfie in forum FlashScan V2
    Last Post: September 13th, 2018, 10:34 AM
  2. T76 Pinout
    By mbsurfersc in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 6th, 2015, 08:51 AM
  3. pinout help
    By vectorbundle in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2009, 09:07 AM
  4. LC-1 to BB pinout
    By s10mods in forum Black Box Logging
    Last Post: December 29th, 2008, 01:28 PM
