Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 66
Thread: Fast90 Woes - Leanness
  1. #21
    Oct 2003
    Quote Originally Posted by TAQuickness
    I was thinking about that today. Bruce's latest entry makes me think there is no hope. I have 5.3's milled 0.024"
    I still have my LS2 TB and and am looking for real alternatives for intake.
    PowrMax Performance
    100 mm PowrMAF
  2. #22
    Jan 2005
    Quote Originally Posted by Bruce Melton
    let me know if you find anything. I pulled my fast this afternoon and started cleaning it up. not sure if i'm going to sell it or give it another whirl
  3. #23
    Oct 2003
    I don't know if you are following this L92 head journey but that looks very promising if the Aussie intake is decent. The heads are incredible and cheap.
    PowrMax Performance
    100 mm PowrMAF
  4. #24
    Jan 2005
    link?
    This has been a heck of a weekend. Laptop took a dump and will be 6-8 weeks before I get it back from warranty.
    Pulled the manifold to inspect for leaks and bottoming out. No signs of hitting bottom, but appearantly Blue RTV is not worthy of making manifold gaskets (between shells). Started scraping the blue RTV out so I can make a new black RTV gasket.
    Although I dont' see signs of bottoming out, the port gaskets appear to have a problem sealing near the valley cover. One of the side effects of a previous sealing atempt, I managed to increase the thickness of a port gasket a good bit (will put the mic on it later this week). I'm thinking I may as well make all the port gaskets a little thicker.
    I hate this manifold.
  5. #25
    Oct 2003
    link?
    I used the GM o-rings/gaskets but you might check to see if the FA$T ones are different?
    http://www.ls1tech.com/forums/showthread.php?t=483486
    PowrMax Performance
    100 mm PowrMAF
  6. #26
    I've used the black rtv and the blue rtv (on various non-intake related things) but I like the copper rtv the best, it seems to stick far better to everything (including your face and shirt and door knobs throughout your house).
  7. #27
    I can just picture it....
  8. #28
    Jan 2005
    I can picture my boy running up with a smoking trail behind him, "Daddy Daddy, guess what?!"
    Bruce - I've been thru both OEM and Comp port gaskets - I prefer the OEM. I got a few ideas while I was sitting in the waiting room. When things start to normalize around here, I'll give them a shot.
    I'm starting to believe a Fast90 that doesn't leak is the cure for baldness.
  9. #29
    Jan 2004
    I am interested then.
  10. #30
    Jan 2005
    Quote Originally Posted by Black02SS
    on the same note, I believe the leaking FAST is the source of baldness. http://www.myspace.com/taquickness
  1. strange leanness
    By mr.prick in forum Gen III V8 Specific
    Last Post: September 13th, 2007, 03:37 PM
  2. Fast90 joys
    By ringram in forum Lounge
    Last Post: June 1st, 2007, 12:15 AM
  3. 2-Bar Woes
    By NAH in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 12th, 2006, 12:58 PM
  4. Fast90 swap what do I need?
    Last Post: October 11th, 2006, 09:41 PM
  5. Wideband woes
    By purrvert in forum General
    Last Post: January 11th, 2006, 04:11 AM
