Results 1 to 3 of 3
Thread: Regional settings?
    Feb 2009
    Default Regional settings?
    So I moved to Toronto Canada and was trying to change my regional settings so I can be compliant with the county I live in. After changing my setting I noticed no change in the program or seeing restricted DTC's. I deleted the program and reinstalled and still no such luck. I'm really confused thanks for any help
    When the EFILive software is installed it checks and remembers the PC's regional settings at the time the software is installed. So you'd need to change your PC regional settings to Canada, then uninstall, then delete the EFILive registry settings, then re-install the V7 software.
    Feb 2009
    Ok thank you Paul
  1. TCM settings
    By Neal S. in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 28th, 2014, 01:17 PM
  2. trans settings
    By aaronr in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 4th, 2008, 04:16 AM
  3. Injector settings?
    By Aloicious in forum Gen III V8 Specific
    Last Post: April 14th, 2008, 03:54 PM
  4. DFCO settings?
    By ScarabEpic22 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: January 19th, 2007, 10:51 AM
  5. PE vs RPM settings
    By ahall1 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 12:28 AM
