Thread: 4l80e lock up question
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    Default 4l80e lock up question
    I'm going to show my ignorance again lol. I would like to adjust the amount of lockup on the converter to 100% or what ever the safe maximum is. But I am having trouble finding the perimeter to accomplish this feat?
    Look at D2903 and D2904... make them both all 100%.
    Mar 2009
    Well this is a little old, but commanding max and min to 100% isn't harsh at all is it? If not I think I'll really like this. Any reason why GM went to a max of 99% and not just straight to 100%?
    99% is close enough to 100%, you won't be able to feel/see any difference.
    As for GM using low minimum % values (in case you wondered about this):
    GM tries to apply the TCC "smoothly", which means is slips as its apply ramps up...
    a quicker non-slipping apply is better for the TCC;
    note that the TCC is applied under almost steady speed non-WOT conditions, so applying it quickly (with no/minimal slip) is fine.
    The key is: after any trans changes you make in the tune, be sure to test drive and analyze what happened.
    Mar 2009
    Totally. I'd bumped my 1500 by 20% and I think the 3500 by 30%. 1500 seemed to respond better which is why all 100% sounds appealing for the 3500 which also has a tighter converter so less of a chance of being harsh.
  1. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 09:57 AM
  2. 4L80E downshift firmness question
    By Wolfie in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 9th, 2012, 01:42 AM
  3. did segment swap to 4l80e have a question
    By Cool28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 3rd, 2011, 10:42 AM
  4. 4l80e question
    By aaronr in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 19th, 2009, 04:44 PM
  5. 4L80e lock up issues. Help Please!
    By sweet71 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 23rd, 2008, 11:10 PM
