Results 1 to 8 of 8
Thread: Changing Calibration ID on E92 ECMs
    Dec 2017
    Default Changing Calibration ID on E92 ECMs
    Hi everybody,
    I am very new in this place and appreciate you patience with me in advance.
    I have an E92 ECM that belongs to a 2016 Chevy Colorado and want to swap it to a 2016 Chevy Tahoe. I changed the VIN using EFILive Scan V7.5 but couldn't figure out how to change the Calibrations. I even tried EFILive Tune 7.5 but the "Program PCM with Currently Loaded Calibration" option is not enabled on E92s.
    Any help is appreciated.
    Thanks,
    You would have to do a Full Flash (Operating System and Calibration)...
    BUT you would have to make sure the new OS was compatible with your ECM.
    Dec 2017
    After full-flash I can use the *.calz file?
    The reason that I am asking is I have found the right calibration in "C:\Program Files (x86)\EFILive\V7.5\Calibrations\E92" folder, but don't know how to use them.
    The .calz files are not the calibrations, they are the calibration definitions...
    you want a .ctz file, you either have to read it from an E92, or you have to obtain it from someone.
    I believe E92s are similar to E38/E67/E39s in that you MUST make sure the OS' are compatible otherwise you will brick the ECM. The correct way to change the OS on these later ECMs is to use GM SPS as EFILive does not flash the DBW CPU (as it cannot be read).
    That is true but then again SPS doesn't do compatibility checks so you can corrupt/brick ECM's with SPS....GM, did it really need to be this hard?
    Yep, it *shouldn't* be that hard, but GM hasn't implemented it so flash at your own risk!!
    Dec 2017
    I have the same issue with E38 computers as well. I explained my problem with an example here:
    https://forum.efilive.com/showthread...on-for-E38-ECU
    Again, thanks for the patience and help
  1. E92 B0184 Flex Fuel Sensor Type not changing
    By trudynosports in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 13th, 2016, 10:06 AM
  2. Changing speedo calibration -turbo 400
    By VX-SS-383 in forum Gen III V8 Specific
    Last Post: March 22nd, 2013, 03:57 AM
  3. Switching ECMs, will I need second License?
    By MMLMM in forum General (Diesel)
    Last Post: March 26th, 2009, 12:48 PM
