Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 60 degrees commanded ignition timing
    Feb 2012
    Quote Originally Posted by statesman View Post
    What map sensor are you using?
    Its a 3 BAR GM brick style sensor . Was running a turbo earlier , hence the 3 BAR sensor . I have a stock GM 1 BAR sensor laying around will try that . Still doesn't explain the excessive timing commanded by the ECU .What I can't understand is when there is nothing in spark table over 30 some degrees , where is it getting the numbers from ? I have a spare ECU laying around was debating switching it over , will have to buy a licence for it first though . Any other suggestions ?
    Feb 2012
    All three codes show up at the same time and only under the stated conditions . The only other issue I've had it, was once I was cruising in the mountains going about 70 mph , it gradually started going lean , till it completely quit . I thought I had run out of gas or the fuel pump quit , even though the gauge indicated half a tank . Hooked up the efilive controller to see if there were any codes , there were none . Tried a calibration only reflash , still no go . Tried a full flash and it started right up . Boy that was a sigh of relief , I was 250 miles away from home , that would have been one expensive tow bill . I was going up a mountain pass , so gaining altitude quickly probably a 5% grade for 20 miles .
    Since you're running no-MAF, you want the MAF DTC to show up always, regardless of anything/everything else.
  1. 0/-2 degrees timing on cammed 2006 GTO
    By Brad Kimbler in forum Gen IV V8 Specific
    Last Post: March 4th, 2017, 01:36 AM
  2. Supercharger/cam ignition timing
    By Kmbellack in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 11th, 2013, 02:36 AM
  3. Idling at -5 degrees timing=$ thrown away
    By killerbee in forum Duramax LLY
    Last Post: August 12th, 2009, 01:58 PM
  4. 4 degrees timing retard needed
    By batesyellow01 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2006, 01:42 AM
  5. Ignition Timing
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2006, 02:47 AM
