Results 21 to 30 of 32
Thread: E92 VATS patch
  1. #21
    Here's the .calz file that will give you the VATS disable patch.
    Same instructions as the previous page showed....
    Save the attached .calz file in to the folder:
    C:\Program Files (x86)\EFILive\V7.5\Calibrations\E92
    With your V2 plugged in before you start the software, open the tune file and navigate to 'B9903', change to Applied.
    You may also need to disable calibration 'G1219', this should stop the need to have a relay wired in to the starter control on the ECM (this prevents them running too).
    For B9903 to take effect you must Full Flash the ECM, this only needs to be done once, after than you can continue with calibration only flashes.
    Please let us know how it goes.
  2. #22
    Jul 2012
    Thank you! I'll get it loaded up and report back.
  3. #23
    I think these need a load on the starter relay output too, I don't remember.
  4. #24
    Jul 2012
    I loaded the file, plugged in my V2 to the Laptop, and opened the file. I now have the VATS Patch in the red engine folder. I have loaded the file to the ecm via full flash, also I am plugged into the ecm itself but there not a "VATS" folder or "Cranking" folder under the system icon where I can turn off the starter relay diagnostic and whatnot. I have a feeling this is going to cause me a problem on the run stand where I currently don't have the original 8 speed auto to plug in (I do have the TCM). The system won't know I am in neutral. Am I seeing the situation wrong? Thank you.
    EDIT: I Posted this without seeing your follow up comment about the relay circuit
  5. #25
    Jul 2012
    I took my time writing that last post, I guess you replied in the meantime. I will work on getting that starter relay pin happy. Should I incorporate a resistor?
  6. #26
    Jul 2012
    I have fire at the plugs but I don't appear to have fuel. I do not see any injector pw on the scanner. Still trying things. I have the starter relay in place.
  7. #27
    I am pretty sure VATS on the late model ECM's kills off fuel and spark, I don't think you can have one and not the other.
  8. #28
    Jul 2012
    I got it to run, but it's so unfathomably rich...something is wrong somewhere. But the VATS patch apparently did what its supposed to do. I appreciate you getting the calz to me.
  9. #29
    Jul 2012
    Quote Originally Posted by Brads_rs View Post
    I got it figured out I think. Here is some info to maybe help out the next person
    Brake switch/TCC: Connector 1 (blue) pin 57, Open circuit for brakes applied and closed to ground for not applied.
    Speed signal out put: Connector 1 (blue) pin 43
    Tach signal: Connector 2 (black) pin 47
    I get no response on the tachometer x2 pin 47. Ive tried 2 different tach, and I've tried a 1k ohm pull-up resistor. I also have zero visibility of tach adjustment in my tune file "system" tab. Is there more functions hiding in the background and I just cant see them in this particular operating system?
  10. #30
    Jul 2012
    Any ideas on this? Please and thank you
  1. E98 Vats PAtch
    By SkyMadness in forum E98 2014+ Diesel ECM
    Last Post: January 14th, 2022, 08:28 AM
  2. E80 VATS Patch
    By jrz in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 13th, 2017, 01:01 PM
  3. Vats Patch
    By derkscustomcars in forum E37, E38 & E67 PFI ECM's
    Last Post: October 22nd, 2016, 06:42 AM
  4. E40 VATS Patch not working
    By SkinnyPedal in forum Gen IV V8 Specific
    Last Post: August 23rd, 2015, 01:42 PM
  5. what is vats patch and how do i use it
    By 400ss in forum Gen IV V8 Specific
    Last Post: July 5th, 2012, 09:10 PM
