Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: E92 VATS patch
    Feb 2008
    Default E92 VATS patch
    Is there any option for a VATS disable patch on a 2017 LT1 using the E92 ECM? I don't see the vats disable or starter relay disable anywhere. This is a conversion were doing, 2017 camaro LT1 into a street rod.
    ECM E92
    OS 12678648
    They are only done when people request them, I'll get you sorted out ASAP. How far off are you trying to fire it up?
    Feb 2008
    Thank you so much, I'm modifying the harness right now hoping to be ready by the end of the week or first part of next week. Im also open to suggestions for a tach and speedo hook up if you would know any.
    Do you need the tune file?
    No need for the tune file, I'll post a .calz file up here when it is done.
    Feb 2008
    Any luck with the calz file? Not trying to rush, just wondering how it was going.
    HD release got in the way sorry..and I am supposed to be having some time off over Christmas (yes, why I my PC on!!)
    Can you give me a time frame when you are really ready to fire it up?
    Feb 2008
    Its actually ready to fire up now. Just need to change a few things in pcm to get it running, Vats and starter diagnostic shutting me down right now. I'm not in a "super rush", I understand it takes time.
    Lifetime Member wesam's Avatar
    May 2010
    I had a problem yesterday with 2016 Corvette C7 M7 that does not has the VATS tab ?
    so I could not disable VATS just applying the VATS patch
    EFILive Tuner
    Feb 2008
    Just checking in to see if there was any progress on the calz file yet?
    Oh no I'm sorry I totally forgot about this. I'll get on to it today.
  1. E98 Vats PAtch
    By SkyMadness in forum E98 2014+ Diesel ECM
    Last Post: January 14th, 2022, 07:28 AM
  2. E80 VATS Patch
    By jrz in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 13th, 2017, 12:01 PM
  3. Vats Patch
    By derkscustomcars in forum E37, E38 & E67 PFI ECM's
    Last Post: October 22nd, 2016, 05:42 AM
  4. E40 VATS Patch not working
    By SkinnyPedal in forum Gen IV V8 Specific
    Last Post: August 23rd, 2015, 12:42 PM
  5. what is vats patch and how do i use it
    By 400ss in forum Gen IV V8 Specific
    Last Post: July 5th, 2012, 08:10 PM
