Results 1 to 5 of 5
Thread: V2 Repair
    Aug 2007
    Default V2 Repair
    The up and down keys on my V2 may or may not work when you push them. It is over 10 years old. How/where can it be freshened up?
    Thanks!
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
    SoCal Diesel can do V2 repairs except I am not 100% sure the keypad connector is the same on the Black V2 as it is on the Blue V2. They might only have the polycarbs for the Blue V2's, I'll get Paul to have a look at this thread and give his input.
    Yes the keypads are the same between black and blue FlashScans. I'm pretty sure SoCal have keypads in stock.
    Aug 2007
    Thanks!
    Jan 2010
    For future reference they do stock the key pad!
    They did one for a friend of mine with a black V2. Looks like New again
  1. serial port failure/repair
    By TrendSetter in forum FlashScan V2
    Last Post: July 24th, 2016, 09:14 AM
  2. flashscan v2 repair process
    By scotte in forum FlashScan V2
    Last Post: August 3rd, 2014, 03:13 PM
  3. v2 repair
    By Boosted GMC in forum FlashScan V2
    Last Post: March 12th, 2009, 03:06 PM
  4. V2 repair help
    By ripmf666 in forum FlashScan V2
    Last Post: May 7th, 2008, 08:48 AM
  5. Repair Translations....
    By GMPX in forum Lounge
    Last Post: April 5th, 2008, 08:43 PM
