Results 1 to 1 of 1
Thread: Dec 2017, Beta Release 05
    Default Dec 2017, Beta Release 05
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFlLive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFlLive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing the Dec 2017 Beta 05 release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.16. To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.11. To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014). To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.129 (Dec 07, 2017). To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
  1. Aug 2017, Beta Release 10
    Last Post: August 28th, 2017, 07:40 AM
  2. Aug 2017, Beta Release 9
    Last Post: August 23rd, 2017, 12:52 PM
  3. Aug 2017, Beta Release 8
    Last Post: August 21st, 2017, 01:45 PM
  4. July 2017, Beta Release 5
    Last Post: August 9th, 2017, 11:11 PM
  5. April 2017, Beta Release 1
    Last Post: April 18th, 2017, 02:31 PM
