Results 1 to 3 of 3
Thread: Cummins Supported Cal IDs
    Lifetime Member Mitco39's Avatar
    Jan 2009
    Default Cummins Supported Cal IDs
    Hey guys,
    I am in a pickle with a truck, it is a 2017 Manual Pickup truck. I am looking for a suitable file for it. I grabbed the identical file for it off insite disk I had but when I opened it in efilive it said it was unsupported (but showed checksum was correct and id'd the file).
    What is a suitable file I can use for this truck (preferably in a E/C number so I can find the correct one). Or if you guys would be so nice to provide one, my normal files do not work because of the NH3 delete (my files are pre NH3).
    File in it as per ECM sticker - DO90053.04. I have DO90053.05 in a bin and while it will let me flash it will not let me edit.
    Thanks so much
    Mitch
    We support the release after that - DO90053.06 32350730AH
    As long as you update to these releases:
    https://forum.efilive.com/showthread...eta-Release-05
    Here's the file.
    P.S - I have CSP conversions for this that need real world testing
    Jan 2009
    Here's the file.
    Thanks so much, I will be CSP converting it and flashing it in to a customers truck (it is just a single tune he ordered but I send all my stuff out with a CSP OS incase I need to log it in the future). I goofed on this truck and sent a NH3 tune so id like to get it right this time around otherwise I would ask the customer for a bit of time with it to test for you.
    Mitch
  1. Last Cummins ECM that supported memory read?
    By crdth in forum Cummins 6.7L
    Last Post: October 8th, 2017, 10:11 AM
  2. Can You Do a Cal Flash on Cummins?
    By arinkuddy in forum Cummins 5.9L
    Last Post: October 7th, 2014, 12:05 PM
  3. E67 supported vehicles & Cal files (Updated 21-October-2008)
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: February 18th, 2010, 12:42 AM
  4. P12 supported vehicles & Cal files (Updated 20-Feb-2008)
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: February 12th, 2009, 11:13 PM
  5. E38 supported vehicles & Cal files (Updated 21-October-2008)
    Last Post: June 17th, 2007, 01:04 PM
