Results 1 to 9 of 9
Thread: Enabling Electric Fans on LQ4 Yukon
    Oct 2017
    Default Enabling Electric Fans on LQ4 Yukon
    I've installed electric fans on my LQ4 powered '02 Yukon Denali off a later Denali using the factory harness and am getting ready to PIN the ECU as per information available online; besides putting values into the tables for the fans do I need to do anything else to get the fans working? Thanks!
    Oct 2017
    Running the factory ECU btw, thanks.
    Dec 2006
    Looking through my old files, I found a 7 part step by step photo's of re-pinning the PCM.
ID:	21709   Click image for larger version.
ID:	21710   Click image for larger version.
ID:	21711   Click image for larger version.
ID:	21712   Click image for larger version.
ID:	21714   Click image for larger version.
    Oct 2017
    Quote Originally Posted by Gordy M View Post
    Awesome, thanks! Thats much more detailed than what I'd found; I'm guessing don't have to worry about the any ECU mods save for adding the temps I want for the controller?
    Dec 2006
    That is what I did, set the temps to come on earlier, as I was towing max capacity in an Escalade. Also, keep three of the relays in the glove box, after about 40,000 miles one of mine went out and I was 200 miles from home and towing an enclosed trailer. Highway speeds was OK but going through Columbus, OH gave me high temps, pulled over and ate lunch to get them back to normal. Never left home after that without 3 spare relays.
    Oct 2006
    You can purchase a stock harness and stock fan setup that will fit in your factory fuse box and not have to worry about relays. The harness part numbers have changed so I don't have current harness number, if you can get an 05 VIN number a check GMPartsDirect it should have the harness number. I also have a DIY harness diagram for stock fans. I believe the harness was for fog lights, and it contained the fans as well had to separate the fan harness form the rest of the harness, comes with stock fuses, the module fits right under the fuse box in the factory space for it just put the pins in the Com and enable in tune. Harness has become expensive from what I saw a few years ago.
    2006 Trailblazer
    Oct 2017
    I've got the factory harness out of an '06 Denali as well as all the fuse block bits; that is the easy part on this one. I'm more focused on the coding part!
    Oct 2006
    Enable fans by Series-Parallel, set temps. Done. Check = A/C>A/C Auto Recirculation>Fan #2 control No coding just parameters.
    2006 Trailblazer
    Just open a tune from a 2006 or 2007 truck and copy with labels all the fan settings and paste with labels the settings into your tune. Then adjust the temperatures if you dont want factory on/off settings.
  1. Electric fans
    By Kunz111 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 31st, 2015, 03:25 PM
  2. electric Fans
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2013, 06:01 PM
  3. Who's converted an '02 6.0 truck to electric fans?
    By HTMtrSprt in forum Gen III V8 Specific
    Last Post: March 9th, 2009, 02:58 AM
  4. PIN out #'s for Electric Fans
    By MN C5 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2008, 11:14 PM
  5. Wish List Item - More control over Electric Fans...
    By MrZ71man in forum FlashScan V2
    Last Post: March 3rd, 2008, 02:42 PM
