Results 1 to 9 of 9
Thread: MAP/TP Correlation
    Oct 2005
    Default MAP/TP Correlation
    I am experiencing MAP/TP Correlation issues at high RPM/MAP that put me into REP mode at WOT in boost. I suspect table C3003 but the max allowed value is only 105 kPa. This won't work with boost if I am reading it correctly. C5501 is set to 2000 RPM. Any suggestions?
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    Increasing C6101 by 100% over stock will get you in the ballpark.
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Oct 2005
    C6101 is already 200% over stock. The DTC I am seeing is P0068.
    Oct 2005
    What was the fix dude?
    2014 VF SV LS3 Maloo.
    Oct 2005
    Only MAP/MAF-related change that I made was to bump up B0120 to well above the highest RPM I will reach as I have no MAF. Guess it hasn't been an issue since.
    If the MAF is still online, then the TB also needs to be checked out.
    Junior Member 64camino's Avatar
    Oct 2007
    I know, back from the dead. I just started randomly experiencing this problem today after not touching the tune for months. Scared the heck out of me cause when it did it it backfired under wot and died, and was in limp mode when i refired it. Did bumping up B0120 fix the issue for good? I have not had a chance to mess with it yet(work) but decided to try to at least research it. Thanks in advance
    Mike
    05 Silverado rcsb. forged 6.0,KBRacing front mount, TC-76, tuned with efi live.
    Oct 2005
    Quote Originally Posted by 64camino View Post
    Mike
    I haven't had any issues since.
    What DTC's were set in your case? Electronic throttle? SD tune?
    Oct 2007
    Only dtc is P0068. Yes it is ETC and a speed density tune. I don't get why it would just randomly start
    Oct 2005
    Could be a sticky throttle blade or MAP sensor issue. From the service manual:
    Diagnostic Aids
    • Inspect the throttle blade for being broken, bent, or missing.
    • Inspect the TP sensor for proper installation. A sensor that is mis-aligned could set this DTC.
    • Inspect the throttle actuator control (TAC) module connectors for signs of water intrusion. If water intrusion occurs, multiple DTCs may set without any circuit or component conditions found during diagnostic testing.
    • Physically and visually inspect the throttle body assembly and correct any problems that you observe. Manually move the throttle blade from closed to wide open throttle (WOT). You should not need to use excess force. The throttle blade should move smoothly through the full range, then should independently return to a slightly open position.
    • When the TAC module detects a condition within the TAC system, more than one TAC system related DTC may set. This is due to the many redundant tests run continuously on this system. Locating and repairing one individual condition may correct more than one DTC. Disconnecting components during testing may set additional DTCs. Remember this if you review the stored information in Capture Info.
    • For an intermittent condition, refer to Intermittent Conditions .
    Test Description
    The numbers below refer to the step numbers on the diagnostic table.
    5. This step will determine if the manifold absolute pressure (MAP) sensor voltage is within the proper range at idle.
    6. This step will determine if the MAP sensor responds properly to the change in manifold pressure.
    7. A throttle blade that sticks or binds may set this code. Opening the throttle through the entire range will indicate problems such as these.
    9. When the PCM detects a condition within the ETC system other DTCs may set due to the many redundant tests run continuously on this system. Locating and repairing one individual condition may correct more than one DTC. Keep this in mind when reviewing captured DTC info.
  1. cam/crank correlation with vortec dist?
    By Aloicious in forum Conversions / Aftermarket Parts
    Last Post: November 15th, 2017, 01:37 PM
  2. IBPW {B4005} {B3701} correlation
    By 5.7ute in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2010, 10:19 AM
  3. crankshaft correlation
    Last Post: May 16th, 2009, 03:04 AM
