Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Public Release #2 (Dec 2017)
    Default Public Release #2 (Dec 2017)
    Release Notes:
    Version Numbers:
    After installing the Dec 2017 Public Release Release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.16 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.12 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.129 (Nov 17, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Issue #3:
    Adding a key to the [Remote] section of a tune file is only active for the following controllers: LS1B, E38, E40, E54, E60 and E67.
    Workaround:
    None.
    Support for additional controllers will be added in a future update.
    Issue #4:
    The E92 controller's serial number is not displayed correctly in the V7.5 software.
    Workaround:
    Use the V8 software to display the E92 controller's serial number.
    Issue #5 (fixed in V2.2.12 - if you have already installed V8.2.11, use the "Check for Updates" option to update to V8.2.12):
    Black Box options for Cummins HD DTCs are incorrectly active for existing non-HD applications. That can cause the "space required" for config files to exceed 100%.
    Workaround:
    Uncheck the "DTC Descriptions" in the "Heavy Duty (J1939) DTC Descriptions:" area of the [F5: BBX]->[F5: DTCs] tab page.
    Or just update to V8.2.12
    Issue #6 (fixed in V2.2.12 - if you have already installed V8.2.11, use the "Check for Updates" option to update to V8.2.12):
    The "Failure Mode Indication (FMI) Descriptions" is disabled and cannot be unchecked from within the EFILive software.
    Workaround:
    Save the BBX options text file, edit the file using Notepad and at the end of the file change the "Active" value for the HD and HD_FMI entries to "N".
    In V8 S&T -> Devices
    when you read the settings from FSV2, the Save button remains greyed out.
    SD card was formatted under V8 S&T -> BBX (Program->Format Config Filesystem), the folders Scan and Tune were created under the tree EFILive->V7;
    In EFILive Explorer, under the Data Files tab, the tree view shows folders Scan and Tune under EFILive->V7;
    when I drag a .ctz file from the upper pane (PC) to the lower pane (EFILive->V7->Tune), the following warning pops up (see pic), and the file is not copied;
    ( when I create folder Tune directly under EFILive, then I can drag/copy a .ctz file to it ok )
    ( drag/copy a log file to Scan folder under EFILive->V7 works ok )
    Junior Member clubby5000i's Avatar
    Jul 2007
    OS 12673958 - I can't get any of the DMA pids to validate? Understand known issue #2, but I can't get them to validate to log in the first place? I have tested the latest update on 8 other E38's with different OS's, and the DMA pids work for them.
    Leppy
    DMA PID's must be defined by EFILive PER OS for each ECM type. Unfortunately that one just hasn't been done which is why it will not validate.
    Although that OS has been supported in the tune tool for a long time now I think we (I) just forgot to go back and do the DMA PID defs. Usually it is because it is actually quite a time consuming thing to do and other things get in the way.
    I'll bump it up the list because that will probably be the last ever E38 OS ever released!
    Jul 2007
    Hi Ross,
    I've been a long time follower, lurking in the forums but not really contributing! Agree with your comments - just thought I would let you know. Always appreciate your hard work.
    Cheers mate
    Leppy
    Ok, I got this sorted out by properly formatting the SD card (you do this from FSV2 LCD/keypad).
    Senior Member DieselMafialb7's Avatar
    May 2012
    Just did this update now every vin has been erased on all my lml tunes in v7???? it just shows ??????????????? for a vin?
    Someone else mentioned this, I don't think they are getting erased from the files (because V8 still shows the VIN ok), it is just V7 is not showing it correctly for some reason.
    Dec 2005
    Never Mind............different issue I had
    www.ridgerunnerdieselperformance.com
    tony@ridgerunnerdieselperformance.com
  1. Public Release (Nov 2017)
    Last Post: December 16th, 2017, 06:53 AM
  2. Dec 2017, Beta Release 05
    Last Post: December 8th, 2017, 12:54 PM
  3. Public Release (Updated Oct 31, 2017)
    Last Post: November 1st, 2017, 09:30 AM
  4. Current Public Release (Oct 2017)
    Last Post: October 25th, 2017, 04:55 PM
  5. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 09:17 AM
