Results 1 to 4 of 4
Thread: Cax Questions.
    Jan 2016
    Default Cax Questions.
    How do i go about creating a .cax file? I know where in the binary the codes and switches are at so how do i take that info and create a .cax file?
    Here is a working sample cax file (which defines 4 tables)...
    follow its format;
    rename the table id codes (see [B0121] [B9021] [B9100] [D0929] in the sample cax);
    add descriptions for your tables;
    rename the file (remove the ".txt" from the end)(the filename must be the os id followed by ".cax");
    place the .cax file in this folder: C:\Program Files (x86)\EFILive\V7.5\Calibrations
    Dec 2015
    I used notepad++, and an occasional python script.
    +1 I use Notepad++ for most things
    ( it is very important to not use a word processing application, e.g. MS Office Word )
  1. Cax Question
    By Chavez91 in forum CAX Files
    Last Post: July 13th, 2017, 05:13 AM
  2. loading in the .cax
    By RADustin in forum CAX Files
    Last Post: June 13th, 2014, 10:03 AM
  3. CAX Files.
    By MICK in forum CAX Files
    Last Post: August 28th, 2010, 11:29 AM
  4. E38 and CAX?
    By gmh308 in forum CAX Files
    Last Post: April 28th, 2009, 04:54 PM
  5. cax file?
    By myws6formula in forum CAX Files
    Last Post: December 21st, 2008, 03:00 PM
