Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: CM850 Support
    Jan 2016
    Default CM850 Support
    Do you plan on supporting the CM850 in the near future?
    We will be working our way back to the older ones once the dust has settled on the more current ECM's.
    Probably the CM870 and CM875 will not be done as they both use Cummins 'old' comms spec, I think the CM850 was the first of the newer comms spec we can talk to.
    But they will be many months off, don't expect anything in the first quarter of 2018.
    Oct 2014
    Any Update on the CM850s?? I've got one I need to tune before spring time.
    Thanks,
    Dominic
    Oct 2014
    So I can get the file to read, but after the ignition time out when I go to save the file I get a pop up that reads
    "Efilive has detected unknown changes in the file that is being opened. Invailid chip address."
    Has anyone else successfully read out a cm850?
    Thanks,
    Dominic
    Dominic, are you using the current public release here:
    http://www.efilive.com/latest/octobe...ublic-release/
    We've had a few CM850 reads sent in so yes it does work.
    Oct 2014
    I did try with the latest public release but I forgot to update my firmware. I'm going to try and read it out again tomorrow with the updated firmware to be sure. I'll send in the read when I get it.
    Thanks,
    Dominic
    No problem, thanks Dominic. Please keep in mind we don't actually offer editing for this ECM at the moment, people are either using EFILive to flash existing tunes in or editing the file outside of EFILive.
    Oct 2014
    @GMPX do you have an ETA for file editing with Efi-Live? I don't plan on tuning the truck until the spring, I just wanted to read the file out and get started before the boat is put up for the winter.
    None of these older Cummins ECM's will be put in the current V7 software, they are waiting for the V8 editor which currently is in limbo for a variety of reasons. At a guess maybe Q2 or Q3 next year perhaps.
    Oct 2014
    I sure hope it's out sooner than later. I would much rather use your editor than Calterm.
  1. CM850 versus CM849
    By lt1stang in forum Cummins 5.9L
    Last Post: March 22nd, 2016, 10:31 AM
  2. Anything new about Volt support?
    By McRat in forum General
    Last Post: June 25th, 2014, 09:25 AM
  3. no 3.8 support?
    By Madspeed in forum General
    Last Post: May 14th, 2013, 10:02 AM
  4. L76 support
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: October 27th, 2006, 05:10 AM
  5. CAN support?
    By QUICKSILVER2002 in forum General
    Last Post: April 27th, 2005, 11:22 AM
