Results 1 to 10 of 14
Thread: E38 L77 tune file request.....Help
    Dec 2017
    Default E38 L77 tune file request.....Help
    Hi,I am having a few issues finding a suitable .ctz/.tun file for my 2011 VE L77 6spd man ute. I bought the ute online from a wholesaler so I was unaware it had some bolt on's and a tune from what must be hp tuners software at the time. In effect I can't modify any calibrations so I need a compatible file to start with. Has anyone got a .ctz to get me started? Compatible versions to mine (12653249) end in 3674,4075,6198,6930 going by EFILive's OS compatibility reference pdf. I have found some that work but they don't have electronic throttle control. I know it's nearly Christmas but any help would be much appreciated.
    Dec 2017
    Starting to think this site is DEAD. Can't belive no one has a stock file for a vehicle that is 6+ years old!!
    The only one's i have that may help.
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Dec 2017
    Thanks mate but pretty sure those ones won't overwrite my current installed file.
    Lifetime Member izaks's Avatar
    Aug 2003
    2011 OS = 12639270
    CAL = 12639269
    OS 12653674 = 2013
    Cal 12653784
    What is the 10th digit of your VIN, as well the 12th
    I have L77 2011, 2012 and 2013
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    Aug 2003
    Apologies, found that 12653249 is 2010
    Quote Originally Posted by Stonecold View Post
    Can you do a screen shot of all the segment part numbers in the current tune? This is important as there is several variations depending on vehicle configuration.
    Dec 2017
    Quote Originally Posted by izaks View Post
    No worries mate, thanks anyways.
    Dec 2017
    This is the only Australian vehicle tune I could flash over. Maybe it is close enough to use, I have been driving to work everyday with it as I was able to adjust a few settings to make it streetable.Click image for larger version.
Name:	Current installed OS.JPG
Name:	OS pt.nm.JPG
    Hope that is the screenshot you were after?
    And the file,
    Aug 2003
    We needed the screen shots of your original file
  1. Stock file request, 2005 6.0 Pickup
    By LBZoom in forum Gen IV V8 Specific
    Last Post: July 8th, 2016, 02:18 AM
  2. TCM file support request
    By Overkill in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: November 13th, 2015, 08:00 AM
  3. Request for E38 log data
    By Gelf VXR in forum E37, E38 & E67 PFI ECM's
    Last Post: July 16th, 2013, 05:50 PM
  4. Replies: 22
    Last Post: January 29th, 2013, 06:57 AM
  5. Cobalt SS or Ion S/C'ed file request
    By ScarabEpic22 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 10th, 2011, 10:30 AM
