I am having troubles connecting with 3 different ECM's, two have tunes locked by the tuner (I am trying to do a full flash from the same tuner), the third was a reman from a GM dealership which had a stock, generic LB7 GM tune with a Tech II (nothing special if you can believe them). I always seem to end up with the $0331 error. The first 2 ECM's already had custom tunes on them with the associated license, the third was a new to me ECM without an EFI license, and I got the same error when trying to set a license to the ECM.
Prior to starting down this process, I updated both V7.5 and V8 software, and updated my V2 using the V8 interface. I have also removed the radio fuses and selected all the unlock features from the Full Flash menu.
Am I doing something wrong? Have I missed something?
I could really use some help on this.
Thank you.
