Results 1 to 10 of 16
Thread: Mutha Thumpa Cam Help
    May 2015
    Default Mutha Thumpa Cam Help
    am trying to get a rebuilt ls1 running a Mutha Thumpa cam idling and running properly. Will use RAFPN etc but I cant really get it to idle so I can apply it. I know everyone says don't worry about AFR at idle but its showing 12.5ish at idle an 22 degrees if I use DVT and lean it out idle improves so I know its to rich. I've been reducing my VE in the idle area to fix this but how low will the VE end up? and will I end up with a very low VE and then a big step up as rpm increases?
    Would anyone have a base tune that I could look at to make sure I'm heading in the right direction.
    Aug 2013
    Big fuel injectors?
    May 2015
    Quote Originally Posted by statesman View Post
    Big fuel injectors?
    Nah mate just factory ones.
    Aug 2013
    Can you give a list of mods and post your tune file and a log of your idle.
    May 2015
    No mods list it’s literally a factory rebuilt spec ls1 with a mutha thumps cam.
    Aug 2013
    You're running that cam with stock valve springs?
    May 2015
    Plus supporting mods in the valvetrain for cam.
    Aug 2013
    Okay. Your VE will be lower at idle with that cam. How low has it gone so far?
    Aug 2013
    I'll have a look through your tune and see what I can find.
  1. Cam Tune help please.
    By sparkinak in forum Gen III V8 Specific
    Last Post: June 7th, 2014, 11:50 PM
  2. cam feedback
    By HINDZY in forum Gen III V8 Specific
    Last Post: February 27th, 2011, 08:37 AM
  3. tuning for new cam
    Last Post: April 26th, 2009, 11:18 AM
  4. new cam and 42 lb injectors.
    By chris10an in forum Gen III V8 Specific
    Last Post: November 14th, 2008, 03:15 PM
  5. Cam is in now what?
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2006, 05:40 AM
