Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: E92 Tables request
    Nov 2005
    The developer and I are catching up next week to discuss.
    Cindy
    May 2010
    I hope those tables will be added to 18 trucks OS 12683365 also
    EFILive Tuner
    Nov 2005
    Pressure ratio limit and desired coolant temp have been added. B5221 was already defined in this OS. The developer could not find B5220.
    Attached is the updated calz file for 12683365 as listed in post #1. We expect that these enhancements will be added to other operating systems later this week. The timing on that will determine if they are included in the next release - I suspect given the current stage of testing that the release may occur before the rest of the OS's are updated.
    Cindy
    Nov 2005
    The next EFILive software release will contain updates to 37 E92 operating systems for desired eng temp, Fan control, Max boost pressure and max pressure ratio tables.
    Cindy
    Cindy
    Great to hear!
    May 2010
    THanks Cindy But I hope if B5220 will be added for OS 12677878 if he could not find it in OS 12683365
    EFILive Tuner
    Nov 2005
    It appears that B5220 is not managed the same way it was from the factory. The developer was unable to find it. If you know the address of the table he can revisit it for you.
    Cindy
    Jul 2003
    What is b5220?
  1. E92 Tables clarification . share me your thoughts plz
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 11th, 2017, 03:03 PM
  2. e92 sacn
    By Ls1_Rulz in forum Petrol / Gas
    Last Post: February 12th, 2017, 08:46 AM
  3. Gent's, can we get two tables please for the E92.
    By PRAY in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 24th, 2017, 11:25 PM
  4. E40 throttle pedal tables cruise tables
    By 04colyZQ8 in forum Gen IV V8 Specific
    Last Post: August 28th, 2014, 06:10 PM
  5. EFI LIVE Tables vs HPT Tables
    By TIM Z in forum General
    Last Post: January 18th, 2011, 09:42 PM
