Results 1 to 10 of 18
Thread: E92 Tables request
    May 2010
    Default E92 Tables request
    Hello EFI team there is one table needed for E92 Cal 12683365 B520A & B520B
    Also there is a desired coolant temperature table that need to be added for all E92 OS cars with 160 thermostat that will change the desired coolant temperature to some thing lower than 90C
    And finally the PRatio tables which is the Maximum Pressure Ratio when the calculated engine torque is invalid such as MAF, MAP or other fault required for engine torque calculation
    Thanks in advance
    EFILive Tuner
    I'll pass it on but some of the staff are away for most of the month on summer holidays.
    B520A & B520B doesn't sound correct, can you please recheck what numbers you meant.
    Cheers.
    May 2010
    Cheers.
    Sorry the labels are B5220 and B5221
    EFILive Tuner
    Thanks in advance
    YES.... I'll second that. E92 has a good few cooling fan tables we could use and in addition, these engines are becoming popular with engine swap customers
    so some of the "other" fan tables would certainly be of help if they are going to look into any of them.
    Thank you.
    Chuck CoW
    Feb at the earliest with staff still away on summer holiday.
    No sweat.... It will be shitty and cold here for another month or so.
    Thanks for looking into it!
    Chuck CoW
    May 2010
    I hope those tables will be added in next release
    I Looked in the latest Beta and still not thing added
    EFILive Tuner
    I'm not sure where it is all at, I'd have to follow it up but if they are not in the beta then they are probably not close.
    May 2010
    Please check and let me know
    EFILive Tuner
    May 2010
    Any updates about this ?
    EFILive Tuner
  1. E92 Tables clarification . share me your thoughts plz
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 11th, 2017, 03:03 PM
  2. e92 sacn
    By Ls1_Rulz in forum Petrol / Gas
    Last Post: February 12th, 2017, 08:46 AM
  3. Gent's, can we get two tables please for the E92.
    By PRAY in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 24th, 2017, 11:25 PM
  4. E40 throttle pedal tables cruise tables
    By 04colyZQ8 in forum Gen IV V8 Specific
    Last Post: August 28th, 2014, 06:10 PM
  5. EFI LIVE Tables vs HPT Tables
    By TIM Z in forum General
    Last Post: January 18th, 2011, 09:42 PM
