You're missing the following elements:
- table id # (enclosed in square brackets),
- VIEW,
- SI_ROW and/or SI_COL (depending on table dimensions/axes).
for example, from a different cax file:
Code:
[D0929]
; Description
DESC.001 = Minimum speed before the PCM will force a downshift to 1st if the gear lever is being held in 2nd.
; Seg Caption Major Minor Vis Dis 2D Grp
VIEW = 4 "Manual Hold Gear, 2nd, 2->1 Shift Speeds" "Shift at VSS" "Downshift" 1 2 0 0
; Address(es) BitOff Bits Typ Inv
ADDR = 17B14 0 16 UNM 0
; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
SI_SLOT = KPH 0.0062496 0.0 1 0 409 0 409
IM_SLOT = MPH 0.0039060 0.0 1 0 256 0 256
SI_COL = "Manual Hold Gear, 2nd, 2->1 Shift Speeds (KPH)" "Value"
IM_COL = "Manual Hold Gear, 2nd, 2->1 Shift Speeds (MPH)" "Value"
SI_ROW = % "0.00,6.25,12.50,18.75,25.00,31.25,37.50,43.75,50.00,56.25,62.50,68.75,75.00,81.25,87.50,93.75,100.00"
IM_ROW = % "0.00,6.25,12.50,18.75,25.00,31.25,37.50,43.75,50.00,56.25,62.50,68.75,75.00,81.25,87.50,93.75,100.00"
