Results 1 to 5 of 5
Thread: Innovate ECF-1 Ethanol Advance Gauge
    Member Age08's Avatar
    Jun 2012
    Default Innovate ECF-1 Ethanol Advance Gauge
    Can the Innovate ECF-1 Ethanol/wide-band 02/ fuel pressure talk to the Flashscan V2 using the serial port the same as the LM-1 for getting Wideband 02 Data?
    Is it possible to gather other data off of the innovate products through serial to Flashscan v2?
    It probably can... can you point me to the ECF-1 user manual pdf.
    Jun 2012
    http://www.innovatemotorsports.com/s...CF1_Manual.pdf
    I know under Devices/F8:Serail I/O you would select wide band type: which lists Innovate(LC1,LM1,LM2)
    It would be neat if you could also get the other data off of this gauge through serial like the ethanol %, Fuel pressure, fuel temperature.
    Jun 2012
    So this gauge does work for the serial communication for the Wide band reading on the Flashscan V2 with the innovate wide band selected on setup.
    Quote Originally Posted by Age08 View Post
    You tried it...? Good job
    Innovate typically make all their stuff compatible.
  1. Ethanol questions - converting non-flex fuel to ethanol
    By BLK02WS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 5th, 2012, 07:15 PM
  2. 06 LLY Fuel Gauge - empty gauge with 7 gallons left
    By timvan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 5th, 2009, 02:35 PM
  3. 10% Ethanol
    By Chevy366 in forum Lounge
    Last Post: December 26th, 2007, 09:33 AM
  4. Ethanol
    By Chevy366 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 22nd, 2007, 01:25 PM
