Results 1 to 9 of 9
Thread: E38 OS12658778 Keep pulling timing
    Jan 2012
    Default E38 OS12658778 Keep pulling timing
    I had this car that keep pulling timing no matter what , it won't go over 13 degree @ wot , I never seen such a thing .
    It happens when I turn off the whole tq management or change any parameter regarding the timing .
    With the stock tune it goes 18-22 degree @wot easily .
    I have attached stock and tuned file .
    tuned.ctz
    stock.ctz
    Mar 2009
    Is this a Chevy SS sedan?
    Jan 2012
    Quote Originally Posted by LastCall View Post
    Yes
    Mar 2009
    Quote Originally Posted by Eng.LSX View Post
    Yes
    I had the exact problem on a 2016 SS sedan today. Timing was a bit higher at 16, but it would not go up no matter what I did.
    I think there is an undefined table (max timing maybe?) or torque management pulling timing. Even happened with the stock tune. Should have logged the TM PIDs.
    Jan 2012
    I think there is an undefined table (max timing maybe?) or torque management pulling timing. Even happened with the stock tune. Never seen anything like this before.
    I think the file gets corrupted with changed parameters but it's definitely the tq management that is pulling , I will get the last update and try again .
    Mar 2009
    When I flashed the stock tune in, the timing was nearly the same. I should have logged the TM PIDs. Did you log any of them by chance?
    Mar 2009
    Any luck?
  1. Pulling timing but not sure where?
    By 02sierra4x4 in forum Petrol / Gas
    Last Post: September 29th, 2017, 01:47 PM
  2. Pulling timing on the 2 step
    By picnic_george in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: October 29th, 2015, 01:46 PM
  3. E38 COS not pulling timing
    By lafinrat in forum Custom Operating Systems
    Last Post: May 12th, 2015, 06:57 PM
  4. Car is pulling timing
    Last Post: February 27th, 2010, 04:55 AM
  5. Pulling timing
    Last Post: August 27th, 2006, 06:40 AM
