Results 1 to 6 of 6
Thread: Base tune for '08 6.2 to '00 4.8 swap
    Aug 2012
    Default Base tune for '08 6.2 to '00 4.8 swap
    I am modifying the 2000 harness and using a 58x to 24x conversion box and also trying to keep everything stock (gauges, stock transmission, etc). I need the 2000 '4896' PCM tuned for the 6.2. What base tune should I use and how should I modify it to work?
    It's likely a L92/LS3 with square port heads, so no LS1B PCM is going to have a super close base tune. I'd start with a LQ4 or LQ9 and run the 02 OS 12212156 (leaves more COS options open and is a more stable OS). Depending what vehicle config you're using (truck, F-Body, Y-body), grab the appropriate base file and Full Flash it on your PCM.
    You'll need to fully tune this as well as update the IFR for the 08 injectors, I believe Joecar has a nifty spreadsheet that handles this conversion so you can plug n play the IFR data from the 08 into the 02 tables. You'll also need to remove VVT or AFM if equipped.
    Aug 2012
    It’s a truck 6.2 from a Yukon. Does this change anything? Would a truck 6.0 be close enough? Change the cylinder volume and adjust the flow rates?
    Mar 2009
    [QUOTE=bubba68ss;243126]Yes it is JoeCar.
    What i was going to say is that:
    Yes, the engine size, injector info, and airflow tables have to be adjusted (VE, MAF, and idle). You should be able to tune it from there.
    The knock sensor tables may also need to be adjusted if they are attached to the side of the block (de-sensitized usually). Gen4 block doesn
    00 Silverado Z71, LQ9 w/ LS3 heads, BTR cam, Whipple 2.9@8#, 4l80E
    uh oh, the forum webapp is truncating replies...
    What 4th-Gen-Engine injectors are you running...?
  1. Running an LS3 swap in an LS1 vehicle, base suggestion?
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: May 24th, 2013, 04:35 AM
  2. help with base tune 6.7L
    By O1Z06 in forum Gen III V8 Specific
    Last Post: August 31st, 2012, 02:04 AM
  3. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 08:16 PM
  4. Need a base tune
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: August 15th, 2009, 02:14 AM
  5. Base Tune?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: July 9th, 2005, 12:11 PM
