Results 1 to 10 of 14
Thread: LML dtc tables no longer active
    Oct 2017
    Default LML dtc tables no longer active
    Hi all
    I did a tune for LML and also remove dtcs, under the tab "engine diagnostic" 2 month ago, today the truck come and i wanted to add 2 dtc, and under the tab "engine diagnostic" the is only "?" and i cant find or see the table codes any more, any idea why ?
    Oct 2017
    just to be more clear, under the tab "engine diagnostic" need to be anther tab "diagnostic dtc" and that is misssing now, i have just MAF, if mybe someone had this problem and know how to solve i will be apricieate,
    Aug 2010
    with what win you work?
    Aug 2017
    Quote Originally Posted by act tuning View Post
    I have the same problem! Did you get this issue sorted out?
    Member Whipped383's Avatar
    May 2011
    Also having the same problem
    Aug 2013
    It's not a problem... it's a new feature.
    They don't want you messing with your dtc's anymore.
    Quote Originally Posted by statesman View Post
    By 'they' I assume you are referring to the US regulators?
    Aug 2013
    Absolutely.
    Apr 2017
    you must have the V2 connected to have access to the dtc activation tables. I had the same problem and what worked for me was to uninstall efilive, search for and remove all efilive entries in the registry, reboot, and reinstall efilive then add the e86 update from March. And you need to set your country to something other than U.S. in clock, language and region in control panel(windows 7)
    Oct 2015
    Quote Originally Posted by Whozzat View Post
    I tried all that and still didn't get them back??
  1. LML Dtc codes
    By Whozzat in forum Duramax 2011+ LML / LGH
    Last Post: January 29th, 2018, 03:13 AM
  2. Description of DTC's no longer available
    By 1chevy02 in forum Diesel
    Last Post: August 24th, 2011, 07:51 AM
  3. Visibility to Active Tables/Variables in Scan Files
    By bobbycollier in forum General
    Last Post: January 10th, 2009, 08:10 PM
