Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: LML dtc tables no longer active
    Apr 2017
    What version of efilive did you install? I am using version 7.5.20
    Oct 2015
    that's the same version im using
    Apr 2017
    I also removed and reinstalled the drivers. I think there is a how to in the FAQ section
    Apr 2017
    same issue guys. whats the fix? i tried uninstalled drivers and made sure the region was New Zealand. reinstalled all the drivers and then updated to new versions. still no luck getting the DTC tables back.
  1. LML Dtc codes
    By Whozzat in forum Duramax 2011+ LML / LGH
    Last Post: January 29th, 2018, 03:13 AM
  2. Description of DTC's no longer available
    By 1chevy02 in forum Diesel
    Last Post: August 24th, 2011, 07:51 AM
  3. Visibility to Active Tables/Variables in Scan Files
    By bobbycollier in forum General
    Last Post: January 10th, 2009, 08:10 PM
