Thread: Logging FPR through EGR.
    Jan 2018
    Default Logging FPR through EGR.
    I followed the instructions to log FPR through my egr on my LS1B (05 silverado) I have adjusted the calc.pids as shown in the tutorial. I just save the file back in the same folder with the same name correct? Does it look right? Thanks for your time.
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    *UNITS
    #Code System Abbr Description
    PSI Imperial PSI "Pounds Per Square Inch"
    # Add slot definitions here
    *CLC-00-001
    PSI 0.00 100.00 .2 "({GM.EGRS}*25)-12.5"
    #Code PRN SLOT Units System
    Yes, save the file in the same folder.
    BUT: your file as you posted above is not complete... after the last line ("# Code PRN SLOT Units System") you should have a line like this:
    CALC.FPR F001 CLC-00-001 PSI Fueling "Fuel Rail Pressure"
    BTW: psi (lower case) is already defined, so you can skip defining PSI, and just use psi (lower case).
    NOTE: after the CALC.FPR line, you should leave at least 2 blank lines (i.e. hit ENTER twice) before saving the file.
    ALSO: .1 precision is maybe more suitable than .2 (e.g. 58.0 psi vs 58.00 psi).
    ALSO: do you want FPR in kPa...?
    If you want FPR in kPa also...
    *CLC-00-001
    psi 0.0 100.0 .1 "{GM.EGRS}*25-12.5"
    kPa 0.0 700.0 .1 "{CALC.FPR.psi}*6.895"
    CALC.FPR F001 CLC-00-001 "psi,kPa" Fueling "Fuel Rail Pressure"
    Jan 2018
    Thank you. I tried to avoid asking simple questions on the forum but i'm trying my best to learn everything. I've spent hours reading through this forum trying to learn. I don't really need to read kpa, PSI should be ok. Just want to make sure fuel pressure rises along with the boost.
    Also, do this:
    remove the FPR manifold-reference hose, and measure rail pressure... this is your base pressure.
    ( and then remember to reconnect the manifold reference hose )
    Feel free to ask (if you don't understand something, it's always better to ask).
    Please make sure you have at least two blank lines at the end of your calc_pids.txt file.
  1. Testing the fpr
    By crash85 in forum Duramax LB7
    Last Post: February 25th, 2014, 03:39 AM
  2. AirDog tired or FPR headed south?
    By DSALRAM in forum Cummins 5.9L
    Last Post: April 21st, 2013, 12:17 PM
  3. Logging LC1 thru the EGR
    By nonnieselman in forum FlashScan V2
    Last Post: April 27th, 2012, 06:14 AM
  4. Changed FPR Now injectors are smoking BAD!
    By stamus25 in forum Duramax LLY
    Last Post: November 23rd, 2010, 07:06 AM
  5. Lbz Fpr Going On Lly Fpr..
    Last Post: February 3rd, 2010, 10:59 AM
