Results 1 to 8 of 8
Thread: 2017 2.8L duramax $0322 error
    Feb 2018
    Default 2017 2.8L duramax $0322 error
    I have been trying for several hours to get this truck programmed and keep getting stuck with this same error $0322
    I have purchased the unlock as well and added it
    Hi Eric,
    The $0322 error notes say:
    A request was made by FlashScan or AutoCal and the controller was not able or ready to handle the request.
    This error may occur prior to reading or flashing late model GM controllers (2017+) that use GM’s enhanced security, if the supplied key is incorrect.
    Where did you get the Auth-Code from? It might need to be revalidated it if there is issues like you are experiencing.
    Feb 2018
    code was purchased from EFI Live website
    Diesel Forum Support Site Admin
    Nov 2005
    Can you please PM me your order number, un-authorized auth-code and authorized auth-code so we can validate the codes? I have looked in the store and could not find an order under your name.
    When you entered the code into the Authorization manager, did you attempt the read with pass-thru reading or BBR? If BBR, did you manually sync the code to your FlashScan/AutoCal?
    Cindy
    Feb 2018
    It would be under the name Shawn Cheecham
    Nov 2005
    The only order in our system for a controller auth-code for that customer name was for a GM Gas E84 controller, not an E98 GM Diesel. That order was placed 48 hours ago. Can you please check the controller selection in V8 pass-thru or the BBX configuration you selected if using standalone.
    It is possible that he didn't order direct, in which case we need the order number or for you to provide the unauthorized auth-code and the authorized auth-code.
    Cindy
    Feb 2018
    Cindy
    would I be able to get your email address?
    Nov 2005
    Hi Eric,
    Cindy at EFILive dot com.
    Cindy
    Sent from my iPad using Tapatalk
  1. 2017 Duramax
    By SPi in forum General (Diesel)
    Last Post: April 15th, 2018, 06:01 PM
  2. 2017 duramax
    By djv86 in forum General (Diesel)
    Last Post: June 24th, 2016, 10:48 PM
  3. $0322 Error
    By darcy in forum Gen III V8 Specific
    Last Post: September 14th, 2014, 11:56 PM
  4. Error $0322 kodiak 4500
    By Rstowe in forum FlashScan V2
    Last Post: August 7th, 2014, 02:58 PM
