Results 1 to 4 of 4
Thread: 2012 chevrolet silverado LML
    Aug 2010
    Default 2012 chevrolet silverado LML
    Is someone can help me to delete only DEF to this cal 12649244 ?
    If someone need I have the stock
    shay
    Apr 2017
    Hi Shay,
    I too am looking for some help with this. My 2012 LML matches yours except for segments 5 and 9. I'm left with only 3 dtc codes to remove, P2033, P242D, and P2471
    Aug 2010
    Quote Originally Posted by Whozzat View Post
    Hi Shay,
    What do you mean segments 5 and 9?
    If you want me to disable these DTC,sent to me the file.
    Apr 2017
    Hi Shay,
    I am referring to ID 5 speedometer and ID 9 from the tables in the pic you attached. I have attached my stock file as per your request.
  1. 2012 lml os 12644096?
    By Mitco39 in forum Duramax 2011+ LML / LGH
    Last Post: June 17th, 2014, 07:24 AM
  2. Speed limiter setting on E78 PCM - Chevrolet Silverado 2500 HD 2011
    By Treurentner in forum E78, E83, E84 PFI ECM's
    Last Post: October 9th, 2012, 01:46 PM
  3. Speed limiter setting on E78 PCM - Chevrolet Silverado 2500 HD 2011
    By Treurentner in forum E39, E80, E82 & E92 SIDI ECM's
  4. 2012 5.3 silverado knocking with stock tune
    By TravRMK in forum Gen IV V8 Specific
    Last Post: February 15th, 2012, 07:21 AM
