Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: Pro Tuning License
  1. #31
    Quote Originally Posted by hacklerjason View Post
    How do i code tag a user? "@" doesnt populate a user list?
    Not sure what you mean.... ???
  2. #32
    May 2016
    In other forums i frequent, i can type "@USERNAME" to tag another member into the thread so they get notified of updates or if i want them to see without sending a link... How do i tag another member in here? The example i would liked to have worked was "@chailand"
  3. #33
    May 2016
    Hey paul
    I confirmed the autocal is on current firmware, ok!
    I confirmed the autocal config files are updated, ok!
    We verified the current installed OS at matching the exact OS we put into "Target OS"
    Any insight?
    please find the requested trace file attached, i will also email
  4. #34
    I don't know the answer to that, try PM'ing Tordne, he's the tech expert for our forum site.
  5. #35
    Hey paul
    Any insight?
    The AutoCal is definitely picking up the ECM as OS=55488112.
    Can you send me the file you are attempting to flash into the ECM? I'll try setting up the same conditions here and see if I can get the same failure.
  6. #36
    May 2016
    Yea that's strange.... The file summary shows the os to be 55508116. I'm getting the files sent over... Will arrive shortly
    Sent from my XT1710-02 using Tapatalk
  7. #37
    Best way to determine what OS is in the ECM is to get the AutoCal customer to perform a "Record Diags" which will save all the diagnostic info about the ECM (and TCM if it is available) into a text file on the AutoCal. Get the customer to send that file and it will show you the OS number in the ECM.
    i.e. The start of the file looks like this:
    Code:
    [INFO]
    DATE=FEB, 20 2017
    TIME=11:20:04
    [ECM INFO]
    VIN=E39W7AFG0H1xxxxxx
    OS=22637084  <-------------------this is the current OS as reported by the ECM
    Serial=86K190xxxxxx
    Calibration ID=N/A
    Stream=E38
    [ECM CVN]
    22637084=A55D
    12635474=2657
    12637167=A6A3
    12625892=36F2
    12633822=25C0
    12635030=9AF1
    12634070=180A
    12635478=4F68
    [ECM Monitor Status (Since DTCs were cleared)]
    MIL=OFF
    DTC_CNT=0
    MIS_SUP=YES
    FUEL_SUP=YES
    etc...
  8. #38
    I don't have the file yet, but I think what has happened is this: The two operating systems: 55488112 and 55508116 are compatible with each other. It appears as though the file you have was read from the ECM when it had 55508116 in it. Then the ECM was updated to 55488112 (maybe by the dealer as part of a scheduled service?). So to override that OS you need to put 55488112 in the Target OS.
  9. #39
    May 2016
    That's the path we're on currently.. it does appear as if that's what happened. The read from the ecm does not match the os we have on stock read out. We're doing a too to bottom revalidation of the data within the files and will report back
  10. #40
    May 2016
    Hey Paul, you were right! That's exactly what happened... Got different software sometime after original read... Took a new read and sure enough we got everything lined up. Thanks for the insight!
    Sent from my LG-H918 using Tapatalk
  1. Pro Tuning
    By Road in forum FlashScan V2
    Last Post: December 16th, 2015, 10:20 AM
  2. Microsoft Surface Pro
    By WisconsinHick1 in forum Lounge
    Last Post: July 24th, 2015, 11:53 PM
  3. Pro Tuning license
    By DURAtotheMAX in forum FlashScan V2
    Last Post: February 1st, 2015, 07:03 PM
  4. Why do a lot of Pro Tuners turn the P1336 enabler off?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2007, 12:59 PM
  5. Tuning license
    By RPO_Z06 in forum Purchase and Shipping
    Last Post: January 14th, 2006, 05:33 PM
