Question??? Why couldn't he set the WOT shift mph down way low like <30mph, then just worry about adjusting the wot shift rpm???
It is my understanding that both perameters have to be met in order for the shift to occur therefore setting the mph down low ensures you are just shifting based on rpm... Do I understand this correctly??
Obviously this wouldn't cure anything if the rev limiter is being hit due to the rpm (due to tccslip) being to high.
