Results 1 to 7 of 7
Thread: Twin Turbo 4.8 wont come off idle
    Oct 2016
    Default Twin Turbo 4.8 wont come off idle
    I have a twin 60mm turbo setup on a 2001 silverado 4.8l running mafless 2 bar cos3. 42lb injectors. It has a loping idle and when the throttle is tipped the engine dies. Anyone have any ideas?01 boost master.ctz. The only way to get it off idle is to set the B3647 table extremely rich.
    I'm looking thru your .ctz and I see some things...
    B3647: columns 95 kPa and 100 kPa are extremely lean, 0.9434 EQR and 0.8545 EQR... check your fuel display units (you will find they are set to Lambda), set them to EQR, restart tunetool, redo B3647.
    B3616: do you want PE to enable when throttle reaches 90% or higher...? I think you should reduce this to enable PE much sooner.
    B3609: you probably want to set this to 0.010 s.
    Oct 2016
    I fixed the B3647, B3616, and B3609 tables, I think. It barely idles now and still can't touch the accelerator without it dying.01 boost master.ctz
    Post some log files.
    Oct 2016
    Ok, so I got aggravated and just built an entire new tune using the custom os tutorial. It will now start and rev, but has a misfire on 4 cylinders and is running rich.
    Oct 2016
    Update, It is running fine and comes off idle perfect. found the issue was my MAF codes were set to not report instead of non emission. Thanks a ton for your help tho. Thats the reason efilive is the best!
    Good job
    ( there was another thread where MAF DTC was set to not-reported )
  1. help with twin turbo tune
    By Cubicylndr16 in forum Gen III V8 Specific
    Last Post: June 16th, 2016, 10:47 AM
  2. 5.3 twin turbo
    By danny68ss in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 17th, 2015, 02:48 PM
  3. Twin Turbo Tuning
    By WisconsinHick1 in forum General (Diesel)
    Last Post: May 12th, 2013, 05:17 PM
  4. Twin Turbo CTS-V help
    By gotabav in forum Gen III V8 Specific
    Last Post: July 24th, 2011, 09:29 PM
  5. twin turbo's
    By limited cv8r in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 15th, 2007, 02:22 AM
