Results 1 to 10 of 16
Thread: Controller Authorizations
    May 2016
    Default Controller Authorizations
    I heard a rumor today i heard is false...
    Are there things going on with controller authorizations that would lead to long lead times for auth codes or make them not available at all?
    May 2016
    Any word?
    Sent from my XT1710-02 using Tapatalk
    They still seem to be processing through the store ok.
    May 2016
    That's good... I heard something through the grapevine about cancellations and gm not issuing auth codes? Idk I'm just trying to cut a rumor off at it's head.... There was a period over this weekend where someone could not get a code and the shop said something about hard time getting codes
    Sent from my LG-H918 using Tapatalk
    Feb 2016
    I
    Quote Originally Posted by hacklerjason View Post
    GM are continually changing things with their systems, there is no guarantee that they won't just shut the doors on everyone outside of their dealers.
    May 2016
    Hey ross
    I had another authorization fail
    Any idea what causes this?
    Did you contact NZ support (they are there now)? I can't do much from over here as I don't see any of the back end transactions.
    Edit: The girls are checking it out now in the store.
    Nov 2005
    Hi Jason,
    The issue is caused by a systems mis-communication. Our technician is currently working on this. For whatever reason the system rejected your auth-code even though the auth-code is correct.
    Cindy
    May 2016
    Hi Jason,
    Cindy
    That's great news! I'm not sure what all happens because sometimes it's flawless and sometime not, but in the end it's always been worked out. I'm not sweating it, just inquiring if it's something we did wrong on our side. Thanks for the help
  1. Vortec PCM/Controller not listed under DVT controller selection.
    By Scatfish in forum Vortec V6/V8 Specific
    Last Post: April 5th, 2015, 12:10 PM
  2. What controller to use?
    By Straight 6 in forum Cummins 5.9L
    Last Post: June 25th, 2011, 01:55 AM
  3. What Controller for a 04 8.1 V8 Engine?
    By 8100 Power in forum General (Petrol, Gas, Ethanol)
    Last Post: May 8th, 2008, 02:20 AM
  4. no controller found
    By mr.prick in forum FlashScan V2 BB Logging
    Last Post: April 8th, 2008, 12:02 PM
  5. V2 controller
    By twinki025 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2007, 05:27 PM
