Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Beta Test Release #2 (Feb 2018)
    Default Beta Test Release #2 (Feb 2018)
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing the Dec 2017 Public Release Release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.18 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.14 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.131 (Feb 13, 2018) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Issue #3:
    Flashing a Cummins HD ECM that has had a master password set via Insite will fail with error $0101 right at the start. If the ECM is already in bootmode the ECM erase will fail.
    Workaround:
    Remove the password and / or recover using Insite, EFILive cannot do this to password protected ECM's yet.
    Dec 2005
    ok one thing to think about after struggles with hidden power shut down settings in my device manager (trying to shut my computer off after 4 hrs)
    I have found if you have a computer shut off unexpected it will not start back where it left off when you hit the restart button.
    If I shut it down it seem to work with the restart button not sure there is a fix for this.
    After getting my computer going I was at 18xxx tries in around 55hrs when I turned my power strip off from habit working late and had to start over at 550 where I had done a manual shut off before.
    There may not be a fix for this if not I am still very happy to be testing this, it is like you where reading my mind when you came up with this idea I am very grateful
    for what efilive has done now or in the past.
    I have limited time to deal with getting a ecm sent out or taking a car to a dealer to get vats relinked ect. working at a racing engine shop as a day job
    This locked 05 gto has been a nightmare with vats on a new ecm but going to be a good beta test car for the unlocking ecms
    All I wanted was a stock tune to start with
    Thanks again Efilive rocks
    Quote Originally Posted by 69camaro5speed View Post
    In this beta version, you MUST click on the [STOP] button to force EFILive to save the progress when stopping. You can't just shut down the PC or EFILive won't save the current progress.
    What I might do in the next update is force the progress to be saved after every attempt. That way if the PC shuts down, the current progress will always be up to date.
    Dec 2005
    I should not have a problem any more unless electric is off for 4 hrs
    That might be a good idea to do if it doesn't slow it down sure would be painful 6 days in for some one to loose power from a storm or something that knocks power out.
    Jul 2003
    Anyway to remove the beta pop up screen? clicking the do not show this again doesn't do anything.. always pops up.
    Doesn't pop up anymore for me...
    post screenshot.
    Senior Member SV8346's Avatar
    Nov 2007
    In 7.5 Tune, Preferences then Options tab, something appears to be cutoff from the bottom of the screen? Its like there is more at the bottom and needs to scroll but no scroll option?
    2016 RG Colorado 2.8TD
    Quote Originally Posted by SV8346 View Post
    You can drag the bottom of the window down to make it bigger (i.e. so no scoll is needed).
    Nov 2007
    Thanks, all good.
    Dec 2005
    Default ecm unlock counting backwards
    I came home from a test drive and find the flash counter counting backwards looks like it made it to 327xx then started counting backwards.
    Earlier today it was 30xxx with close to half the progress bar to go.
    so I hit the quit button then tried to restart with the restart button checked it started over at like 561
    I did a screen shot of it counting backwards
Name:	2018-02-25 21_40_21-EFILive Scan and Tune.png
  1. Beta Test Release #1 (Feb 2018)
    Last Post: February 12th, 2018, 06:20 PM
  2. September 2016: EFILive Beta Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: October 18th, 2016, 08:53 AM
  3. July 2016: EFILive Beta Test Release
    Last Post: September 5th, 2016, 03:18 PM
  4. May 2016: EFILive Beta 3 Test Release
    Last Post: June 6th, 2016, 07:30 PM
  5. Known issues with the April 2016 Beta Test Release
    Last Post: April 18th, 2016, 05:07 PM
