Results 1 to 2 of 2
Thread: Beta Test Release #3 (Apr 2018)
    Default Beta Test Release #3 (Apr 2018)
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing the Dec 2017 Public Release Release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.19 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.15 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.132 (Apr 27, 2018) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Aug 2010
    Hi
    After installation, the PC does not recognize the efilive V2 USB at EFILive V8 in EFILive V7.5 work find.
    firmware 2.07.113
    boot block 2.07.007
    •EFILive V8 software: V8.2.15
    I try to uninstall an install with driver manager its not work
    there are ideas?
  1. Beta Test Release #2 (Feb 2018)
    Last Post: March 19th, 2018, 05:54 PM
  2. Beta Test Release #1 (Feb 2018)
    Last Post: February 12th, 2018, 06:20 PM
  3. May 2016: EFILive Beta 3 Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: June 6th, 2016, 07:30 PM
  4. April 2016: EFILive Beta 2 Test Release
    Last Post: April 30th, 2016, 08:49 AM
  5. Known issues with the April 2016 Beta Test Release
    Last Post: April 18th, 2016, 05:07 PM
